O
oz_fenda
G'day,
First let me say I had a real dillema working out which section this should have gone in so appologies in advance if i've posted it in the wrong spot.....
Anyways, I've been using Audition 2.0 for a while now and find it really user friendly etc....Recently i've started using cubase however i find it alot less 'user friendly' and alot more complicated etc......
My question is; soon i'm going to be recording my solo EP, will spending hours trying to get the hang of cubase (yes i've tried reading the manuals etc
)mean i'll yield results sound quality wise that are much better than using Audition which i'm more than comfortable with?
Also in audition I'm sure there was a thread ages ago with little shortcuts etc I tried searching for it without any luck, anyways was after a shortcut key that can be pressed so that you can see the incoming sound levels down the bottom without having to be recording?
Thankyou so much in advance, cheers,
Matt
)mean i'll yield results sound quality wise that are much better than using Audition which i'm more than comfortable with?Also in audition I'm sure there was a thread ages ago with little shortcuts etc I tried searching for it without any luck, anyways was after a shortcut key that can be pressed so that you can see the incoming sound levels down the bottom without having to be recording?
Matt
