M
muyinchen
hi guys! My first time here.
I'm new to home recording. Have only been recording with Audacity, and am now trying to use Audition CS5.5
I have been trying different settings and have also posted in Adobe Audition forum but no one could figure out what the problem was, so I thought I'd see if anyone here knows how to solve the problem.
I am plugging three condenser microphones into Tascam US-800. It records with Audacity just fine.
However, when I record with waveform in Audition CS 5.5 with Tascam US-800, it does not work. I am able to press down the record button, but it won't transport.
Needless to say, I am also unable to record in Multitrack with Audition. the record button is actually grayed out in Multitrack mode.
Since my Audition works when I record with my built in(I'm on a PC, windows 7) mic and speaker, I figure it's a setting issue. However, I cannot figure out what the issue might be.
Below are my "Audio Hardware" settings in Audition. I have tried both of the following settings but neither worked...
first setting --
Device Class: Asio
Device: US-800 Asio Driver (somehow I'm unable to change the "settings" or sample rate when the device class is set to Asio)
I/O Buff size: 250 samples
second setting --
Device Class - MME
Default Input: (Microphone US-800 Audio)
Default Output: (Microphone US-800 Audio)
Masterclock: (Out:Speaker US-800 Audio)
Latency:200
Sample Rate: 44100
anyone can help? I'm really at my wits end here
mollie
first setting --
Device Class: Asio
second setting --
Device Class - MME
Latency:200
Sample Rate: 44100
mollie
