warble
Hey all-
After doing some searching on the BBS here, I've found a variety of postings relating the the same issues I have:
I have an Asus A7V133 MOBO and the VIA KT133A chipset. You might imagine what I'm going to say next.....
Every time after audio is recording using the analog inputs of the card, my multitrack software (Vegas 4.0) upon playback has clicks and popping noises which are very obvious in the recording. I've tried 24 bit and 16 bit modes. 24 bit seems to introduce more problems, and even 16 bit is causing the prob.
I have:
Tried different m-audio drivers: both version 5027 and 5029.
Moved the audio card to different PCI slots.
Updated my software to Vegas: version 4.0c, and have tried numerous things in the software configuration trying to alleviate the problem.
Updated the VIA 4-in-1 Drivers. I'm now using Hyperion Drivers version 1448v.
Tried a PCI latency patch written by George E. Breese (this patch was a possible solution posted on the Homerecording.com BBS).
I have my system running fairly lean without too many extra sevices (I am on a small network, and am connected to a router for DSL). I have SQL Server Developer installed (use PC for web dev too), but have it OFF when doing PC recording.
When recording using Vegas, I have no other programs running at the same time.
Tinkered with the Audiophile control panel: changed DMA buffer to various settings, etc.
Question is: do I get rid of this card and move to something else (I used to use a Turtle Beach Santa Cruz with zero probs.) - maybe the Revolution 7.1 from m-audio? I absolutely love the sound quality of the Audiophile, but have simply run out of patience trying to troubleshoot this damn thing with my system.
I don't have the $$ or time to upgrade my MOBO to something that uses other than the VIA chipset.
Regards,
Warren
I have:
Regards,
Warren
