Audacity to record 24bit/48khz uncompressed, .wav files?
  • Thread starter Thread starter chaoshead
C
chaoshead
Member
Can i use Audacity to make a .wav voiceover/narrating recording that's 24 bit/48khz and uncompressed? If so, how do i do that? I am using a PC, an XLR-mic (Røde NT1), Behringer UMC202HD.
It's in the Quality settings/preferences for the application. You can actually set your application to record 32-bit float, which will probably be better in case you have any peaks over 0dBFS. When you export the project audio, just export it as WAV, and choose 24-bit from the File Type drop-down.
You should make sure to normalize it to whatever is being requested/expected, assuming it's going to be processed/mastered by somebody else, i.e., you are shipping a raw, unfinished recording.
Thanks for the reply. I found that in the settings, yes. It was already set to 32-bit float by default, it seems. But, since the person who asked me to make the voices for him, said mentioned 24-bit 48khz in the job assignment... Should i still have it at 32-bit float or should i just put it to 24-bit?
Also, a small problem... I cannot find 24-bit WAV in the dropdown menu for some reason... where is it?
EDIT: Ahh, I found it under "other uncompressed files", sorry.
Just set that when you produce the finished thing. Work in 32.
Yes, run at the best system you can, 32 bit float then Export as 24 bit .wav.
I do similar all the time because Audacity will record anything going through this Lenovo laptop except I record at bog s 16 bits and export 16 bit 44.1kHz .wav coz its not going to get any better!
