A
acorec
Banned
ausrock said:Motor checked out OK once I swapped it to the LH supply chain, it appears that both motors get their supply from the one source, this feed splits to supply each motors' "Joint PCB". One thing I can't figure at the moment is what the 2SD1047 transistor on the "TR PCB" does. Unfortunately, these things aren't the cheapest transistors I have found and sourcing them locally isn't over easy so we don't really have the option of buying a fistfull and swapping them over just to see what happens.......we have to attempt to eliminate and also understand components before we start surgery.
The pic shows the schematic for the "Joint and TR PCBs", if anyone can figure out what the TR transistor is there for please tell me.
Regards...........![]()
Just a quick look here:http://www.ampslab.com/PDF/2sd1047.pdf
That transistor is the one that controls the voltage to the motor (which is a DC motor). I can't tell from looking at the schematic exactly since the control signals coming to/from the TR PCB are not named in the pic, But, I can tell you that the transitor in the pic is a 140V/12A/60 Watt trans. That is a hefty transistor. The base of the trans is the control pin, and the collector is connected to the motor directly. You need to put a Oscope on the base and watch for the signal to go "High" (it is an NPN tranny) when you hit the proper button. If you get a changing signal on the base of the transistor, and +24V on the collector, then the trans is bad (The trans acts like a switch to ground, completing the circuit for the motor). If there is no changing voltage on the base, or no +24V on the collector, then you have to trace through the circuit to find where the missing signal(s) is.
Good Luck.
