pingu
No ADC sucks majorly.
indeed it doespingu said:No ADC sucks majorly.
You can in fact see the delay amount, in samples, that each plugin requires in Cubase and Nuendo. With the latest versions compensating for the FX busses as well though, this is more for satisfying curiosity than anything elseLeeRosario said:In PT, you can physically see if there are any offsets (in samples), so that's kina helpful, but not that it applies to things like Nuendo or Cubase.
Some DAW titles do indeed sound different. They shouln't. I don't quite get it. But they do.Robert D said:OK, this slays me! I've been arguing for a long time that different DAW software sounds..... different. This argument has been against a seemingly majority opinion who say "it's bits in - bits out, which software you use doesn't make a difference." So.... different EQ plugins sound different (of course they do), but different DAW programs don't? Hilarious!![]()
NL5 said:The full blown PT rigs have delay compensation? I thought none of them had it. Seems like without that, mixing would be mighty difficult.
NL5 said:If you sum ITB, then the different summing algorythms are of course gonna sound different. If you use any of the other audio "features" they will sound different. However, if you are simply sending tracks out to your converters raw, they should sound the same....
No summing, just playing back a raw WAV file; no signal chain, no extra processing, no panning.NL5 said:If you sum ITB, then the different summing algorythms are of course gonna sound different.
pingu said:I agree with ya there SSG.
You should give Saw Studio a run around the block. To me its hands down champion.
One thing i love about saw, when you pan an instrument, you can clearly hear it with pin point accuracy at the panned location specified.
It use integer math for its summing not floating point.
Sally sells it for seashells by the seashore.ds21 said:I see you say saw was some swell software...
