D
Dan DA
I could use some help from all of you Cakewalk geniuses.
I've spent the past few days searching the web for solutions to this problem, but none of the suggestions work.
When using a Delta soundcard, I get a static/crackle on random takes. I can never tell when it will happen, and it is very frustrating to lose a good take this way. It doesn't seem to matter what sampling rate I use. I've tried every buffer setting I could think of, and nothing works, although some of them result in fewer bad takes because of crackle. Oddly, it only does this in Cakewalk. I can record all day in Wavelab or Cubase without a hitch, so I'm assuming that the ASIO drivers work well, but the Windows drivers don't. I'm using the latest Delta drivers, but I've tried all of them, without success. Here's my setup
Abit KX7-333R (the raid is disabled in the BIOS)
Athlon XP 2000+
1 GB PC100 RAM
Maxtor 7200rpm hard drives, a seperate one for audio
Windows 98SE
Thanks for any help.
Athlon XP 2000+
1 GB PC100 RAM
Windows 98SE
