Steenamaroo
hey all,,,
i've started into a wee project, with limited knowledge,,but i'd say i'm capable..
i understand the immediate reaction may be "buy a pre racked preamp", but i'm doing this for a bit of fun, and i'd really appreciate a wee bit of help, so,,,here's my situation
I have an auditronics 110a input channel with 3 band eq
i have a JLM transformer and 5 rail power supply.(0v,+24v,+15v,-24v, -15v and 48v)
I've put together a test setup on the bench, and have wired the following...
psu 110
+24 to +24
-24 to 24v common
+15 to +15
-15 to -15
+48 to +50
and 0v to power supply common
XLR INPUT
xlr input hot and cold, to mic input a + and - on the 110.
and the xlr ground sleive to input common on the 110
i've run an earth wire from the panel/case of the preamp, and the mounting holes of the psu, to plug socket earth (as i figure these will ultimately connect to the rack chassis..)
OUTPUTS
i've taken program out and program common as the outputs. I read somewhere that they are the outputs to be used in conjunction with the jensen output transformer
i haven't attempted to use the jensen transformer yet,,,i just wana keep it 'simple' for now.
i've wired the output to an amplified speaker set that i don't care about, and plugged in a cheap dynamic mic, but the audio output that i'm getting is very very distorted, and has lots of harsh buzz/hum.
i'm waiting to get hold of a volt meter,,,all i have at the minute is an electric test screwdriver, but,,i'm getting a slight live reading from all three xlr terminals!??!
I've contacted Joe at JLM,,,lots of people said he was the man for these projects, but i thought i'd post up here too!
I'm a beginner with limited knowledge, and this is a steep learning curve, but if there's something obviously wrong that you can see, i'd very much appreciate your help....
if it helps, i have schematics, and can post up pics/lists if necessary.
thanks in advance all!!!
psu 110
+24 to +24
-24 to 24v common
+15 to +15
-15 to -15
+48 to +50
XLR INPUT
OUTPUTS
