Anybody try the Black MOuntain Ring slide that is one size fits all spring loaded? You can play guitar with your fingers normal. Then slide when you want on a string or two.
What do I use as a picker some may ask. Well Beak has some bullshit for the masses. stainless steel has the least deflection. Then it comes down to thickness and ergonomics. There is a lot there to discuss. Softer options are slick cellulite, or soft torex if you like metal picks, you'd gravitate towards the softer metals than stainless, like zinc or nickel. Don't leave out the ergonomics, like a depression for your thumb and forefinger tip. Sand paper. Grip tape. Printed or pressed grooves for stability and tight gripping control. Stylus? forgetaboutit. Pick technology has come a long way. $45 bones don't scare me.
But, kidding aside, I'm a shitty slide player and naturally bought a whole bunch of slides over the years figuring THAT was the problem, and this is the one I've settled on:
Fits well, the little cutoffs and whatnot may be a little gimmicky and honestly if it didn't have them I'd still be fine... but it's a tight, controlled fit, and the asymmetrical shape actually works really well, with the thickness varying over the slide's length.
