Any such thing as reliable one-click software to fix digitized LP recordings?
  • Thread starter Thread starter brassplyer
brassplyer
brassplyer
For transferring LPs to CD is there such a thing as software that has a "fix it" button to do a solid job of removing surface noise and clicks/pops without much need for further adjustment by the user?
I have noise removal software but it's laborious to use particularly click/pop removal to avoid artifacts that degrade the good part of the sound. I go through a thorough vacuum-irrigation LP cleaning process which removes a lot of the problem but sometimes defects are just embedded into the vinyl. Wondering if in this day of AI there's a more sophisticated, reliable solution out there.
Thanks
I tried a few free programs. None was great, I did a fair amount of manual removal on a couple of albums. Audacity has some tools, but I felt they were mediocre.
There are several commercial ones, some with trial periods.... VinylStudio, Izotrope Rx, ClickRepair are a few. I think I tried Wave Corrector.
I agree with you. This would seem to be a perfect application for AI but I haven't tried any of these.
Doesn't have to be free, I want it to work.
Probably best you run the demo versions. Unless you know that it works, it's silly to blow money on something totally unknown.
I have and use RX11 Advanced - there is no quick and easy way to eliminate Pops, Clicks or other Record noise - I don’t know any software that is point and solve to remove the kind of noises incurred on records.
I looked at it - gads $1349. And it's still not point and solve. Presumably it's useful for other things besides LP cleanup?
I suppose perhaps you should look at it differently? Unless you intend to offer cleanup as a business, digitising your collection is a one-off. Anything you spend becomes obsolete when the job is done.
You can get a month's free use of (what was Sony) Sound Forge from MAGIX. I used it years ago to clean up 50 sides of punk 45s for my daughter and burn to CD.
Not quite, IIRC, a "one button fix" but not onerous to use. You might also ask around to see if there is a professional record cleaning company you can use. Some library's had a KMAL machine you could buy time on.
I;ve been upgrading for a while - I think the latest was $159 - and it’s very useful for issues with recording.
Click Repair by Brian Davies is a pretty good piece of software - doesn’t cost anything - and heres a video that explains it pretty throughly.
I've got a pretty big collection.
I really only bothered to transfer albums that are not available via CD, etc. like some of my old Nautilus and Sheffield records that were limited number pressings and some other records that are long out of print. Direct to Disc albums were usually limited pressings of several thousand since there was only one lacquer made, and they concentrated on quality of the pressings instead of making the most stampers they could before the sound was trashed.
A couple that I transferred:
Tim Weisberg - Tip of the Weisberg
Randy Sharp - First In Line
