arcanemethods
Some folks on rec.audio.pro have had very kind words for the ultra-cheap MCA SP-1 available from Musician's friend for, I think, $39. I'm wondering if anyone here has given it a spin.
It isn't really a large diaphragm. I got one and immediately extracted the capsule and it's 18 mm, more in the SDC range.
It is an excellent example, IMHO, of the principles I've been espousing of high quality, low cost, repeatable capsules made possible by careful attention to manufactuability during design.
The design is novel and clever. Obviously thought through for solid construction yet ease of manufacture. One big screw instead of lots of little ones holding it together and the diaphragm tension looks to be determined at final assembly which means it could easily be tensioned while stimulated and producing output to give consistent results off the line.
The downside I see by inspection is that the diaphragm is recessed into the housing by 3 or 4 mm which could give some unevenness or drop off in off axis HF response.
Bob
Bob
