Another RNC thread...
  • Thread starter Thread starter El Barto
E
El Barto
I've had the RNC for about 2 years and have not properly used it. Granted, there was a period of time in which I was moving around from place to place and had to put my home recording off to the side, but now that I am settled I have picked it up again. The problem with the RNC is that I have no idea what each knob does, and ultimately, how to get it to do what I need it to do. I would like to use it on bass, vocals, and acoustic guitar. For bass, I would like to get a pretty flat and even sound, so that one note isn't louder than another note...it should all be pretty even. For vocals, I just need it to keep the volume in check. Sometimes I unintentionally sing certain parts louder than others. Same with acoustic, just keep the highs in check. If anyone could provide a description of the knobs, or better yet, an RNC website with lots of fun info, I would very much appreciate it. Thanks in advance!
do a search on compression
Its way too much info to type and im sure everyone else is going to tell you to do the same thing.
Theres a link or two to some good articles on compression. Im sure someone can point you in the right direction.
www.studiocovers.com/articles3.htm
Lots of good info about the basics of compression and limiting at that site. After you have absorbed some of it, hook up your RNC and experiment. It takes a bit of trial and error to learn how to use compression well.
Yo, El Barto! Essentially, compression involves 4 parameters. Ratio, threshold, attack and release. The RNC has these plus a gain knob. The gain knob is a parametric fader, in effect a volume control. The Brits call ratio compression, and threshold slope. Ratio determines the degree of compression. Threshold indicates the level at which compression begins. Lets say your threshold is 100 decibels and your ratio is 3:1. This means the compressor theoretically does nothing until the signal reaches 100 dB. For every 3 dB above 100, the compressor allows 1.
When you get to the point where *nothing* is allowed over the threshold (say a ratio of 25:1 or higher), the compressor becomes a limiter. Attack defines how fast the compressor will act in response to a signal that is at or higher than the threshold, and release determines how soon the compressor will stop compressing when the signal drops below the threshold.
So for your bass, you want to send a pretty hot signal to the compressor with a pretty high ratio. If the signal is not hot enough going in, your volume will vary on softer stuff, as the compressor won't act on the soft stuff at all. You will want the threshold fairly low and the ratio fairly high, so your hot signal does not clip (overload) the preamp.
For your vocals, on the other hand, you want a relatively high threshold and a low ratio, probably not more than 3:1.. Like antilock brakes, most of the time the compressor will do nothing, acting only on that occasional excursion over the threshold.
In the bass scenario, use a slower attack and release, because the compressor will be acting most of the time. With the vocals, a fast attack and release will keep the compressor from acting on stuff you don't want compressed (most of it).
I don't claim to understand the technobabble behind "supernice" but my ears tell me that you turn it on whenever you power up the RNC, and pretty much leave it on all the time. Hope this helps.-Richie
