Analog to Digital:
  • Thread starter Thread starter Creamyapples1
Creamyapples1
Creamyapples1
www.murphycabs.com
In the computer based recording age, I still prefer using an Analog board to "fine tune" my mixes. I've been reading up on some d/a a/d converters and what not, but I do have a question that I can't seem to find the answer to.
I'm currently looking to use an eq in the final stages, this one caught my eye.
http://www.musiciansfriend.com/srs7/g=live/search/detail/base_pid/182493/
It has the digital output, but how does that work if I'm using an analog input? Does this work the same way as say ....
http://www.musiciansfriend.com/srs7/g=live/search/detail/base_pid/701205/
If not, would you suggest running the last analog piece in my chain to the converter then into the eq? Or do I totally not get it?
Or just the converter to my burner? and get a normal eq?
Those items couldn't be more different... One is a (really bad) graphic EQ that (IMO) has no business being in anyone's recording rig.
The other is a fairly decent stereo converter set.
If you're already going out to an analog board and you want to tweak the EQ on the 2-buss, I'd suggest just getting a decent used parametric. Orban, DBX, Ashly - Something along those lines.
What are your mixer's outputs currently going to for mixdown - Back to the PC? Stand-alone burner?
Stand alone burner, would a a/d d/a converter still be worth looking into?
If it's a better converter than in the burner.
What I was thinking was last analog piece to a/d convert to digital input on the burner. I have a Pioneer CDR that I picked up probably 4 years ago. Would the A/D convert digital out to digital in on the burner be better overall compared to letting the burner do the converting and using all analog ins/outs?
(apologies to Massive Master! :) )
Seriously, the only way to tell for sure is to try it both ways and pick which one sounds better.
lol I had a feeling someone was going to say that. Thanks for the info guys, I'll add this to the list of things to do.
