Analog to Digital! I Jumped into the Volcano!
  • Thread starter Thread starter saxxman
saxxman
Greetings I am a newbie to this forum. I recently completed purchase of DM3200 with IF-FW/DM mk II and Sonar 8.0 Producer. I've had years of analog studio workings (Aardvark / Sonar). I thought it would be easy! Looks like I JUMPED ..not slipped into the volcano. I CANNOT record midi to audio or audio direct. I think I have it all set up right. My midi communication is ok and the ASIO drivers are in place. Bottom line is I cannot figure out how to line up the routing to do the things above. I guess I am a dummie because the manual is confusing. All I need is a simple road map to set up for recording midi to audio. Also listen to midi and recorded audio (different channels ofcourse). Could use some help!!! It would be GREATLY appreciated!!
:confused:
You'll need to bounce / render the midi track (or whole mix) to waveform. Picture your software as both a midi-sequencer & multi-track machine time-clock-locked together. No amount of playback will magic the midi-synth audio onto the multi-track, you need to record from one to the other or to a stereo master. Try Googling for stuff like 'Sonar render midi' if the supplied documentation isn't helpful enough!
I don't quite understand your other question about playback, though others might!
