W
Whyte Ice
The Next Vanilla Ice
Today I was looking through some junk and I found this thing called Amp7000 High power 80 watt amplifier by Sparkomatic.
On the left side of the unit, it has four speaker slots (2 left, 2 right) and directly under it says "RL: 3 ohm x2". There is also a slot that is called "Fuse 5A" and directly below that is a "Power In" slot.
On the right side of the unit, it has a low input section with 2 (left, right) RCA plugs and beside that is a Input Level knob and beside that are four speaker slots just like on the left side of the unit (2 left, 2 right) and below that it says "High Input".
On the back there is a sticker saying, "This amplfier is compatible with all Radios and tape decks including GM Undergrounded units. Refer to the special instructions enclosed with owners manual. AMP7000 high power 80 watt amplifier. 12 Volt DC Negative Ground."
I don't have a manual or anything for this, I just found it in a pile of junk and don't have a clue what it does.
