Amp Tubes: 6L6 Vs. EL34
  • Thread starter Thread starter 64Firebird
64Firebird
64Firebird
A friend told me yesterday that if I replace the 6L6 tubes in my Fender amp with EL34s it'll distort at a little lower volume. Is this true?
EL34 instead of 6L6 in the price of only rebiasing ?.... doesn't make sense to me, as far as I know you should change some crucial elements in the amp's circuit for this. My suggestion is just buy a Marshall, leave that Fender alone it is ment to be a clean sounding amp after all. If you still want your Fender to break up earlier I suggest looking at the direvtion of using 6V6 that are lower power than the 6L6.
gilwe said:
EL43 instead of 6L6 in the price of only rebiasing ?.... doesn't make sense to me as far as I know you should change some crucial elements in the amp's circuit for this. My suggestion is just buy a Marshall, leave that Fender alone it is ment to be a clean sounding amp after all.
If I turn this amp up to about 7 it's got the most wonderful smooth distortion I've ever heard. But, that's too loud for most of the places that I preform (this is a LOUD amp). I was thinking of getting something to put between the amp and speakers to suck out some of the juice, but this will do the same job and cost no more than retubing. Besides, I don't like the way that Marshalls sound.
Changing the tubes will not lower the value of this vintage amp, so why not go for it?
I didn't say don't go for it, I said that EL34 doesn't fit a Fender amp unless you modify it.
You can't just pop EL 34's into a 6L6 amp and adjust the bias unless is was designed to accept both types; your Fender isn't. Partway down the page below are directions to switch a Fender to EL34's.
Fender - Marshall amp mods:
They might start distorting a just a little earlier, but I doubt enough to warrant a change, if you could even notice a difference - Marshalls can be pretty frickin' loud while still clean. Also, part of that power tube-saturated tone is from the output transformer reaching its saturation point, it won't be quite there if your volume is only at 3 or 4... One other solution would be to try THD Yellow Jackets - its an adapter that you can pop right into your sockets with no mods, self-biasing, and uses EL-84 tubes. They will put out around 20 watts (I think) which is loud enough for club use (although it won't drive your output tranny into saturation). EL 84's rock, they have a great distortion character, and are way cheaper than 6L6 or EL34 tubes. The Sovteks are a price/performance champ - they sound great, and can be had as low as $7.95 per PAIR ( I just got some at that price). JJ/Tesla's version is highly rated, they are about $15-$18.00 per pair. I think the Yellow Jackets go for around $70.00 per pair without tubes.
I think Major Tom has by far the best suggestion. They do have adapters for EL-84 use and you can get the tubes with adapters from Musician's Friend and I don't think they're too high priced. I think that's how I would go.
Also do not put 6V6's into an amp that uses 6L6. The plate voltages are too high. You can use 6L6's in a 6V6 amp though for a cleaner tone.
And yes your Bassman can use EL34/6CA7's with some minor wiring mods. It will have a much different tone that way in addition do distoring at a lower volume. Not much lower though....
I think it's gonna sound more Marshally actually with the EL34, which, Firebird, you said you don't like anywany...
Spot-on! A Plexi Marshall is basically just a copy of a tweed Bassman with different iron & output tubes.
Interesting, are you sure these are basically the same amps ?
however I beleive that much of the tone that is known as Fender or Marshall tone is a result of the power tube types they use.
Look at the schematics, and the control layout. They are vitrtually identical. The early Marshalls even have the 4 input jacks!
anyone know a good place to find info on plate voltages/interchangability/etc for many, many tubes? i just picked up 100 of them for about 10 bucks, and think i want to experiment with them in some of my toys..
i got a grab bag of pulled tubes for about 10 or 20 bucks. many types in there. i was hoping to at least come up with enough to make my wonky old PA amp work (uses 5 tubes-4 different types!), and i'm pretty sure i can, but i want to know exactly what kind of leeway i have as far as experimentation. between tubes and amp, i paid about 25 bucks, so it's not like i have much to lose.
A quick Google search put this page at the top.
There are lots of vacuum tube related sites. If you dig around a bit I'm sure you can find just about anything on the net these days.;)
