Amp Recommendations
  • Thread starter Thread starter BurnBarfield
B
BurnBarfield
Hello, I am looking for a small recording amp. At most I'd like to spend 200-250. Maybe less if possible. Tube or solid-state whatever will work well for a pop-punkish style. Please, don't laugh at me:). hah.. Well, more or less like MxPx, Weezer, Rufio, Slick Shoes, maybe even AFI, etc... I know most use Rectos, but I can't afford that. And would it be better to maybe get a V-amp, or Line 6 Guitar Port (looks best for modeling recording). Right Now I have a Carvin SX-200, ADA MP-1 Rack set-up with a few pedals. But I would like to add a new amp. Please help me? The amps I was looking at were the Tech 21 Trademark 10, Pignose G-40, Vox AD15VT, Vox Pathfinder, Kustom Tube 12, Roland Cube 15, Alesis Spitfire, and Epi Glaxie. I know long list, I would be willing to try anything that would work best for my style. Thanks for all your help.
-Aaron
I have a vox pathfinder...good for recording but probably not what you're looking for. The sound you're looking for will require quality high gain, which I honestly don't think can be had in an amp for $250. As far as recording goes the Line 6 Pod would probably be the best solution for you in my opinion. The Fender Blues Jr. and the Vox Pathfinder are probably the two recording amps at or below the $300 range that I would use. Try them out, maybe they'll work for you, but I suspect if you try out the Pod you'll like that more for your uses.
I've got both the Vox Pathfinder, the Trademark 10 and a Jay Turser (20 watts?). For recording, I would recommend a modeling amp like the Trademark (or SansAmp) or a Pod or whatever. I've use the Trademark (and a SansAmp) for recording and have been very happy. I usually put a ART MP tube preamp in line to add some tube-ish vibes to it. Then I DI into the recorder.
The only thing about the other little amps is that they are either clean or some level of gain/distortion - that can be a great thing if that's within the range of what you're looking for. But it's amazing what those little amps can do.
The downside of the Trademark 10 is the speaker - I'm not entirely happy with that. It's a little 8" job with no bottom. The Jay Turser and Vox both have a nice full sound. I think the Turser may actually have the nicest clean sound IMHO.
I've been through a few of the little practice amps - I've also had an old Peavey Rage (solid state - not bad) and a little Alamo tube amp (not very loud - but very ZZ Top).
Be sure to audition (at home if possible) each one. Unless you can actually hear it with your ears, you may have an unpleasant surprize.
For recording I really like the Line 6 POD or V-Amp gear. Direct connects, produces a range of sounds, and is quiet during the recording process.
Ed
