G
gusfinley
Okay, so I modded my amp (DSL401) - adding birght switches to both of the channels, removing a unnessasary capacitor that was limiting the bass response and added pin jack to the back of the amp so I could check the bias without taking the amp apart.
So i put it all back together and fired it up - no sound - then the sound faded in and there was all this crackling and stuff and then I watched on the 1/2W screen resistor burn up!! YIKES!! I looked around and found that I hadn't connected the HT to the output transformer - it was way in the back and close enough to the place it was supposed to go that it looked cennected when I double checked.
Well, I was only running my amp with two tubes anyway, so I put the two tubes in the outer sockets. I turned it on and then I see lots of blue sparks in the tube that was in the socket when the screen resistor burned up. WOAH!! Well, I have like six spare tubes so I put in another set and everything seems ALMSOT alright....
One strange thing is that when I turn down the master volume all the way now, I still get a signal coming through the speakers..
there is also a permanant hum. It almost seems as if the master volume knob is more like a presence knob now because the volume doesn't change as much as the tone does - crank the volume and it get bassy, turn it down and it gets thin...
I am assuming that somewhow somewhere the signal from the phase inverter is sneaking past the master volume and into the grids...
one more odd thing.. I was cheking the differences in the circuitry between the two tubes. and noticed that when I connected the lead of my multimeter to pin 2 of the leftmost tube there was a loud pop. When I connected it to pin 2 of the rightmost tube there wasn't a pop. This was the same for the inner sockets that contained no tubes (including the one that had failed previously) The left one popped and the right one didn't..
anybody have any suggestion as to what might be the problem here? It is baffling me!! Thanks for any input..........
