Ambient Sounds
  • Thread starter Thread starter Erockrazor
47ronin said:
There are a lot of so called folktronica bands like The Postal Service, Caribou, or artists like Four Tet and Boards of Canada that use acoustic instruments with electronic touches.
I like a few of those bands and I understand they arent really going for anything realistic. I like the way it sounds and may pursue the use of midi intended for uses like that. On the other hand , if i did take that route I would try and be more tasteful , I think id be a little hesitant to get too much midi into my songs because then my live performances wouldnt be as intriguing. But I like the use of midi in that sense.
scrubs , so youre saying maybe i should literally go for more ambient noise within the mix. Experiment miking farther away to get soom room sound in there , add some reverb to the vocals, etc. Good Ideas , Ive been fairly repititious with my vocal miking. Im usualy about 8 inches away above or below the mic (due to lack of pop filter). On the contrary , I watn a pop filter so i can sing closer to the mic and pick up more of my low end of my voice with proximity effect. I feel like it would make my vocals sound a little more full. I like the reverb on the vocal suggestion. I always feel like my vocals sound very dry , but aside from reverb , I have no idea what effects to use on my voice without sounding completely absurd. Good Suggestions Scrub. :)
I don't think you had mentioned whether you had a second mic, but I've been pretty happy lately with using a mic in the nearfield of the acoustic guitar with a second a few feet away (follow the "3:1" rule) to pick up the room sounds (I have a small room.) Then you can adjust the two tracks' volumes to taste and pan them apart to give it a little width. In my experience it really helps beef up the guitar.
Ill take that into consideration Easlern. And yes I have two mic's in which i can stereo mic it with. Today I'm recording with my friend at my house. So if all goes well , I will have recorded some tracks that i would be willing to show you guys with your techniques applied and maybe we'll be lucky enough to hear an improvement. Ill keep you updated. Thanks alot.
Alright I took some of your suggestions and put them to work. I recorded a mix of one of my bands newer songs today. I posted a new thread in the mp3 mixing clinic but for any of you who were checking up on this thread. www.myspace.com/asleepatawake1 .. the songs name is "quite quiet"
thanks so much for the help guys. :)
im happy with the way my mix came out
Erockrazor said:
Nobody in particular , but how bad would going MIDI be in these types of situations. Do many people use MIDI for backing noises and effects, etc.
If you have the MIDI stuff available, go ahead and try it out and see if you like it. I just figured since your existing tracks are acoustic and sound pretty good, it would match better to have a real cello sound backing them up.
Otto
I agree- the real thing almost always sounds better than a virtual instrument, but time- and budget-wise it just makes sense sometimes. I'm pretty happy with the bass in Drum'n'Bass Rig, and the piano in Key Rig doesn't sound terrible either. How does the saying go: "close enough for rock and roll?" ;)
This may be a late after thought since you have receved alot of info and such.
When I use to record alot of acoustic stuff I would add just a drone sound in the background in the key of the song with a key board.
It doesnt have to be huge just sublte.
Beck has done this quiet well and it adds a much needed layer in some cases.
Sort of like if you were a painter and wanted to paint a sky you need the base colors first and acents after.
Just a weird Idea that may help kick start you a bit.
-Blaze
