Re: Lag On Triggering Units
Analytical Man said:
Ok Tim, We obviously used different methods for triggering. And i was in no way trying to start any flaming here. I never trigger, and mic the bass drums...and mix them. I either mic, or trigger...so i can see where you are coming from there. But even live when we use it i don't notice any latency issues...and niether does our drummer...who is anal and hates triggering the drums. I force him to...hehehehe! I mainly use it for recording where i usually trigger everything, and mic the room, and cymbals...so perhaps i have totally missed the latency issue here. I guess it all depends on how you are gonna use it...i agree that the Ddrum, and Roland Modules are by far superior, but to call the DM5 a peice of junk doen't really do it justice. And for the money it is a good peice of equipment, especially for those who want to just trigger kicks or snares. However some of the sounds could use updating...too much 80's-90's verb on alot of stuff. I have also never used it in a midi chain, which brings me to a question perhaps you can answer. I have a drum machine which has the majority of the sounds of the high end roland modules...can i use the DM5, or DM Pro to trigger sounds from it using midi cables connecting the two. I know there is a way, but i have never done it. And if the latency is a problem i will probably just buy a Vdrum module like the TD 10. I am happy with the Alesis i just want more sounds. If you know of any way this can be done let me know.
Nope, I didn't take it as a flaming war.
That was just my experience with it.
I had to delay all the tracks to line up the Mic'd tracks with the triggered ones. It triggered exactly what I played into it-it was just delayed enough so that it sounded like a slapback echo was on the kick drum....when really I probably needed to have it ahead of the tracks-because you always get the "attack before the boom" in the kick sound.
You can indeed use it to trigger MIDI from another soundsource...which is what I was doing, therein is where the major lag in time REALLY shows up.
Try it
For econo uses, it's not bad, but I just wouldn't use it myself.
I have an old ddrum unit (one of the original ones from the 80's) and I wouldn't use that one either....it is very....how can I put this nicely...it's kind of like an old Simmons unit.
I've been toying with E-drums for almost 20 years...I had a Simmons setup (
SDS9), a Pearl X-10 Rack(I think that was the model number...it was a rackmount unit, and sounded just like the Simmons did) and finally the ddrum unit when it was hailed as king of the heap in the late 80's. (Think of the band "Europe" - their drummer used this same ddrum system.
I became interested in E-drums, because the drummer from Manowar used a system called "The Drums of Death System" made by a guy named Vince Gutman (the company was caled "MARC Industries") and they were sort of like JL Cooper...a smaller boutique company that specialized in Electronic drums....it had an onboard "Sampler"(EEPROM Blower) and each drumsound was (supposedly) stored across several EEPROMS so that you got more than an 8-bit storage. (we're talking 1985/86 era here.)
The closest thing I've seen to it is the 0.0 Module by Boom Theory/Space Muffins, but I'm not sure if that unit actually allows for Sampling.
http://www.boomtheory.com/Space/index.html
This system allows you to have up to 8 sounds layered per drum, so that when you hit at different velocities, you get up to 8 different sounds.
Anybody who is really interested in E-drums should join "Logiztics Electronic Drums"...a site for people who DIY E-drums.
It costs 20 for a year to become a member, but you'll learn a ton...it was worth it for me.
http://www.electronicdrums.com/
What really needs to be created is an EXTREMELY fast triggering processor, and a Sampling unit all in one-that does not utilize MIDI to convert the triggers signals to trigger the samples...sort of like a Trigger input straight into each Sample bank.
I fully believe that it is the "Trigger-to-MIDI-to-Sound" process that is the real reason for the latency.
Tim
