Turning,
Yes, there is some of that 'analog' warmth, maybe a bit of hiss.
Your string samples are good ! I have found that samples of the cello usually work the best. And your sparse use of it, makes it much more effective also. In the second phrase of the initial string intro sample, the violins are at a volume level a bit higher, (because of their natural sonic range). Mixing the violas just a bit left of the cello, but still in the right stereo field, and then mixing the violins a hair to the left of the cello and violin, and much, much lower, will retain much more feeling of authenticity in the strings.
And what I'm really trying to say here is ... the string part is well written and very appropriate, but the violin samples 'inherently' sound less real than cello, so mixing techniques to mix them even better into the cello, makes it all more authentic. Generally the violins are popping out a bit to much then.
I love strings and record with real violin, viola and cello so I get excited when I hear good use of them.
Your vocal is a very good quality performance.
Your vocal is mixed out top, I can understand all the words on the first listening. You have a very cranberryish vocal !
But if you listen to their mixes, you will instantly see her vocal is mixed at least 2db louder than yours, maybe 3db.
There are a few words, just preceeding 02:27, which are a bit difficult to understand.
When you fall into your upper baritone, low tenor range, the guitar in right stereo is in almost exactly the same sonic spectrum. If you will pan your voice right just 1 or 2% , this will give your voice some seperation and distance from those frequencies in the guitar in stereo right. The listener can also be 'turned' to hear your voice there, and then brought back to center.
'Moving' the listener is trick with the vocal, the center for the vocal is hallowed ground, but you could do it effectively hear.
SECOND LISTENING :
The intro guitar in stereo left is well placed. It's close to 9:00 perfect, which is a extremely difficult to manage ... but it works. I would put a bit more delay, make it even a bit more dreamy and liquidy. You have a very good signal on that guitar, so that would work really well, and that guitar has considerable 'body', the part is played very well.
Your vocal could be 1db-3db louder, (especially when in the low range), and I think there is plenty of headroom to push the fader up a bit.
At 1:16, that break is very, very effective, but I'm losing your vocal at the entrance, and the entrance is the critical point.
At 1:42, the formula is well executed, but again, I really think your vocal could be more 'present' by just bringing the instruments down 1db there ...
The theme of your song is interesting 'can't see anything, everything ... ' , reviewing your fellow posters work, will give you all the keys !
Use of strings in the outro vocal is very nice, I would double those tracks defining the 'leader track' in the left field and then put a second set of string tracks in right stereo nearly directly under the vocal also, mixed almost inaudibly, just for color there.
The strings in the final outro are very nice and I would craft their exit, they seem to stop abruptly, just extend the length of that note, and draw a nice fade envelope on the pad.
Thanks for sharing, this is a KEEPER, I like this song, your voice, and the performance.
