R
Robertobly
@ cjacek
I won't be buying anything for a little while. I'm going to be researching all parts of my future setup & trying to match things that will go together first (from recorder to cables!) Thanks for taking the time to look, the reason I asked you to look was so I could get a better idea of what I'm looking at when I'm scouring eBay looking at various machines. So, I've learned that photos of the heads, tape lifters & guides is a pretty good gage of condition, thanks! I see some of the machines are obviously from professional enviornments, if they don't say so I think you can tell a lot from the photos, which is, I assume, a desired prerequisite when looking for a machine in good nick!
I think I get the general gist of compression now. I will learn the ins & outs later when I'm teaching myself about recording techniques & such like.
@ _brian_
Thanks for the advice about compression. I will be placing more priority on getting the essential pieces of kit first (to a very good working standard) & learning about mic placement & room treatment before I decide to add on extras such as compression & reverb (although I doubt I will use reverb, I'm looking for a very simple setup to record the instruments as the sound naturally- obviously the recorded sound is room dependent to!)
I'm guessing priority is something like- 1. Musicians 2. Instruments 3. Room & room treatment 4. Mics & mic placement 5. Recorder (with good tape at desired ips) & mixer. Then such things as cables, compression, good headphones & monitors. What d'ya reckon? Anything I've missed, anyone?
I will almost certainly be buying good condition used equipment. Perhaps not for cheaper things like cables etc.
@ Talldog
I'm not at all worried about what any piece of kit looks like, except instruments, PA & anything else needed for live work. I agree the Tascam 388 is along the lines of what I require. Unfortunatley I doubt they come up as much as other models & I'll be buying quite local. There is one on eBay at the moment but I'm not buying just yet!
I may have to pick out the best working machine I can find that is within driving range when I do 'pull the trigger' as cjacek puts it
Thanks for the advice on effects, I've noted them all down & will consider them in the future when looking into compression etc.
@ Everyone
So...What's the general consensus for Soundcraft mixers. There seems to be a lot of good deals on eBay, especially the Spirit models (& newer Spirit M). I'll probably be using a mixer for recording & live (unless I end up with a Tascam 388). My P.A. has powered speakers so I don't need to worry about that. The older Tascam M series seems to come up quite a bit.
Thanks again for all your learned advise. Already know way more than a couple of days ago!
Rob
@ _brian_
@ Talldog
@ Everyone
Rob
. Are you considering recording everything at once or tracking the instruments individually?
Ok, it's not bad preamp wise, but I'll be upgrading to a soundcraft spirit m when I can & yes the mackie was dearer than the soundcraft - we all make mistakes but it was a long time ago!!
