WERNER 1
Member
Hey guys, I finally got a chance to sit down with my buddies Taylor acoustic and run a couple of test tracks.
I was looking to get some feed back as to your thoughts on the over all tone. Keep in mind one track is "dry" with no eq'ing or anything, and then the next is EQ'd just a bit.
I was wondering if you all liked the dry or eq'd tracks better?? (The Eq'd ones sound a bit better on my monitors, but the dry ones sound better on my home stereo (High end stuff)
Signal chain: Taylor guitar ---> (2)- SP B1 mic's---> DMP-3 ---> Delta 1010 ---- AA 1.5.
I also wanted to point out that the strings on the Taylor were totally shot and dead, so I would imagine that with fresh strings the dry versions would be just about perfect.(??)
Mic Placement: I had both B1's about 12" out from the front of the guitar. One was facing the neck/body joint, and the other was facing the bridge.
Looking forward to your thoughts and suggestion!!
PS - I also added some verb and panning to the very last clip/passage.
Thanks,
Rick
http://www.soundclick.com/bands/songInfo.cfm?bandID=410286&songID=3829318
Thanks,
Rick
.....sounded a bit boomy to me though.....of course the strings were in extreme need of change.
