A Question about test tones
  • Thread starter Thread starter Bguzaldo
B
Bguzaldo
So I have a test tape with a 1k tone on it. I also have a 1k tone generator on my console. The problem is they are two different pitches. So I assumed my deck wasn't running at the right speed so I downloaded some test tones and played them from my computer to my board... again two different pitches and the downloaded tones don't match the tones from the test tape either. Three 1k tones from three different sources...three different pitches. Almost all of the tones I found online are the same pitch so maybe my console's tone generator isn't calibrated right and maybe my machine also isn't running at the correct speed...
Any insight?
If the computer gives a higher pitch, I would think it's from overclocking on a cheap mobo. Just a guess. I would def suspect the machine if all the clips on the web are the same and it doesn't agree. Machine is low, correct?
EDIT
Sorry, you said console, not computer :facepalm: Is there a calibration on the console that you can adjust? I would still trust consistent input from multiple sources as correct.
My Console is the highest pitch then the test tape then the computer. There is no calibration on the surface of the console, I'm not sure about the interior the manual doesn't mention it anywhere.
Surprising, I figured the tape would be lowest. Still, if you calibrate the tape to the consistent source, you should be good to go.
Yeah, when I record my console's tone to my tape machine it plays back at the same pitch so I'm not in any serious danger...just thought it was a bit curious
Speed/pitch accuracy has always been of concern to me (even though I'm not in possession of absolute pitch.)
You can always trust a 1KHz tone generated from a computer to be exactly the right frequency, because the sample clock is derived from a crystal oscillator.
I've never seen an (old) console that gave an accurate 1K tone. (My old Studiomaster's was something like 1300Hz!)
That tone is only intended for setting levels.
MRL states that the frequencies on their tapes are accurate to within 0.5% - the frequency on the tape should be between 995 and 1005Hz. The speed and flutter (3150Hz) test tape is even more accurate.
What kind of machine do you have?
If it's very old it will have an AC synchronous motor for the capstan. The speed will be governed by the power line frequency (50/60Hz), which is generally quite accurate. In this case there isn't anything you can do about the tape speed besides build a variable speed oscillator (connect a sine wave oscillator to an amp large enough to generate a 120Vrms waveform and run the motor off of this - I haven't ever had the occasion to try it!)
More likely your machine has a DC servo capstan motor. The motor has a frequency generator built into it and this frequency is compared against an internal reference to run the motor at a constant speed. In cheaper machines this is generated by an RC oscillator, which is quite stable, but does drift (there is an internal trimpot for it) - in the really professional ones the servo reference is crystal-derived, and the speed is really rock-solid.
If you are intending to use your tapes on other machines you should try to make sure yours is running at the right speed - though it's not terribly likely anyone else's is, since no tape machines have been made for 20 years, and most of them have been poorly maintained. You should at least record a reference tone (A=440Hz is easy, then you can check it with a standard guitar tuner) so you do not end up having to tune the playback by ear when doing overdubs. If the 440 always plays back at the same frequency on your machine there is nothing to worry about - if it doesn't, that would indicate that the capstan belt is slipping or there is something wrong with the motor.
I occasionally send 2-track masters out for record cutting and always include the most accurate 1KHz I can - and instruct the mastering engineer to check it against theirs and vari-speed the machine if necessary.
Yes, any kind of "analogue" CR oscillator is going to be off frequency a bit and subject to drift but for a desk lineup purposes that does not matter a jot since you are only interested in level and thermistor or FET circuits can keep this very tight indeed.
Best source, as said is a computer. You can also measure frequency to within a digit with even the cheapest digital multimeter, IF the matter bothers you!
Even for tape deck response line up a few Hz either way is of no great concern.
