Hey guys,
First of all, the Meek mic-pre does not add any color. Hell, its green, that's color enough.
It is actaully a very warm clean mic pre on its own. It is the photo-optical compressor and MeQ (eq) that adds the "tube"(harmonic 2nd order), or coloration you are hearing, which by the way is adjustable, so you can use just a small amout if you want less flavor, but as a stand alone, with no eq or compressor, the mic pre is very good and transparent.
All the new Joemeek mic pres are changing over to the new CS (current sense) design. It is a good design that helps load any microphones impedance properly. The impedance matching is important, and the Viper, which is another impedance matching mic pre at almost $2.5K is getting a lot of attention in the high end world. You know impedance matching is something users are concerned about, especially in the high end studios.
Truth is, Joemeek was way ahead of the Viper on that issue with its VC7 a couple of years ago, but Joemeek has found a better and less costly method to do it. So if you care to read a little on the matter of impedance matching, go to:
http://www.joemeek.net/press/csmode.htm
As for the C1 and acoustic guitar, I think the C1 is great on acoustic guitars. JD MARS, Pete Leoni, Ted Perlman, and Harvey have all said good things about it, and Telefunken's first attempt ain't bad at all. It certianly will work for Flamenco guitar, but just like your track Rich, you need to work with the mic, pre-amp and placement a little more.
The C1 will give you great results if you hone your skills a little more. In addition, I always back mic an acoustic guitar. It adds to the depth of the sound, but I prefer the C3 or T3 for acoustic guitar.
Speaking of the C3 and T3, with all the hoopla on the C1, there has not been a whole lot of talk on the C3 and T3, which (sales hype) has come down in price, while the RODE has gone up.
Look, I can go into the studio and do some demos with some very good mic pres. I have them all, including some Dan Alexander Telefunken mods, but I will tell you this, I am not a fan of these tests. They end up being done on mic pres most of you can't afford, not to be a prick, so what you end up with is a sound you think you like, but may not be able to afford. In addition, some of you may not like the style of the tracks, so you end up satisfying some, but not others.
In any case, I am off to the NAMM Show, but I wanted to touch base you guys and address some issues.
