A
andydeedpoll
i do love smilies...
about the CME UF5. i got mine today, and i think it's ace, so far
but i was wondering, is there any way of changing the setup so that the faders do not automatically change the volume of that midi channel? i know you can change the "fader function" 3 times, so you effectively have 24 faders rather than 8, but i would rather use all 24 for control of effects/synths, rather than volume, which i can set manually and leave (unless i want to specifically set it up otherwise.) i'm using Reason, if that helps? though i think its more likely to have something to do with the keyboard itself, because it mentions this in the manual (just not how to override it...)
i was also wondering if there's a way to change the setup so that, in Reason, i can switch to different instruments via the program knob, and not have to switch to the channel select button, which automatically jumps back to the program select function after 3 seconds or something... i hope that makes sense!
thanks for any help,
Andy
Andy
