D
Deleted member 196982
Guest
A couple short mandolin duets. Not a lot going on - the usual little bit of EQ, compression and small room reverb. I'm not sure about the stereo pan - too wide?
These are J.S. Bach Inventions 3 & 4 in D and Dm, transcribed for 2 mandolins by Mike Marshall and Caterina Lichtenberg. Played probably about 2/3 - 3/4 tempo. Works in progress, but our son only visits a couple times a year and I usually only get a few hours to go through some of these and set the mics up. These were recorded last week just before we took him to the airport. (Might be a year before we get together with mandos again.)
p.s. 1ea Soyuz 013 FET SDC mics on each mandolin, maybe a foot or a few inches less, tried to aim for the lower (treble) f-hole. We were just a couple feet apart, so the mics probably about 4', so inevitable bleed. The tracks are not panned full LR in the mix. In Logic the pan dial goes from -64 to +64, and I had these set at -40/+40.
p.p.s. (edit) looked at them in the iZotope Imager (part of Ozone) and also Insight, so it looks like the instruments are a bit inside the 45/135 degree marks, i.e., not wide-wide. Doesn't bother me through the monitors but in the headphones I'm not sure.[/MEDIA]
