K
Kelly Dueck
I've been lurking for some time and love this bbs! So please forgive me if my first post is rather "bold."
I've attached an mp3 that features a quick "shootout" between several popular, low-cost, chinese-made condensers, namely the MXL V67G $219, MXL 2001-P $179, NADY SCM-1000 $149, MXL 603s $79 and a newly introduced tube mic called the SE Electronics SE5000 $299. This one looks like an AKG C12 knock-off and sounds . . . well . . . download the file to find out for yourself.
Technical notes:
All mics went into the same pre on an Aardvark 24/96 soundcard, using the same cable recording at a 16-bits and 44.1Khz. Gain was set to the same level for each for comparison of "hotness". Distance from mic was about 6" for each mic, regulated by the use of a nylon pop-filter. The mp3 is encoded at 192 Kbps
I used each mic to record the same short spoken-word passage describing the theory behind condenser microphones, followed by a section of very short clips recorded with each mic so as to allow for an easier comparison before one's audio memory becomes unreliable.
Of course this is a very specific shootout, for a very particular application -- spoken word. However, since most of the mics are large-diaphragm condensers, very commonly used as "vocal mics" I thought it would be a useful starting point. The small diaphragm 603s is included mostly for interest's sake and, truth be told, was hard to use without getting a lot of "popping" in the signal.
The mics were recorded in a typical crowded home-studio setting with a computer fan screaming in the background. I could have gated it out but I didn't want to effect the signal path in any way. It's hardly scientific, I know, but I hope you find it interesting, nonetheless.
Also, the file is almost 4 Meg so be patient!
Kelly Dueck
Technical notes:
Kelly Dueck
(I'm assuming you saw that thread). I was hoping for so much more from that mic, but on the bright side, I just saved myself $299.....
But that is just what sounds "better" to my ear, which on do you think represented your voice "accuratly"?
