COOLCAT said:
will people give a thumbs up on 96Khz...will they plkug it in and be blown away by the pure awesomeness of improvement over 44.1?????
I want to know this before I buy .......so I don't waste money.
Short answer: NO.
Longer answer: If you want to look at bang for the buck: the answer to that should be pretty self evident. Every thread and every discussion and every post on this subject tells us one thing: any advantage to 96k is debatable and marginal at best. In other words, 96k yields, at worst, questionable, and at best, limited "bang". How much buck is questionable or limited bang worth? Wouldn't you have to say that extra buck for it is therefore also limited or questionably worth it?
There's another more practical angle to look at: what do people listen to? At this point it's either CDs, MP3s or streamed audio, with DVD-A and SACD so far looking like fairly major flops as far as market penetration and the cares and needs of the buying public. This means a vast majority of distribution format that's at 44.1K or
worse. That's the target audience and the target medium. Does one need 96k to deliver top-notch content to these media? Nope.
Let's take a stand on the other side of the coin, let's look at best case. Lets say that through some kind of market manipulations that several things happen more or less at the same time: that DVD-A or SACD replaces CD as the new disc standard, that MP3 and standard streaming are replaced by a losless compression format that improves the reproduction quality greatly without much if any bandwidth cost, and that you are producing Telarc-worthy classical or acoustic productions that are both the domain of the audiophile end user with the golden ear and are also the type of content where smaple rate makes the most difference. In that case you want to go to 96k, right?
Well, sure...with a big "BUT". That "BUT" is that you had *first* better upgrade everything that falls in your signal chain before the converter, and that you had better not only get a 96k converter, but you'd better get an A-list one, otherwise just upgrading to 96k is going to be a huge waste of time, money and bandwidth.
It's been said here before many times, but it's worth repeating now, I think: 96k does not make content sound better, it only - at best - reproduces it more accurately. Again, look at the wide screen DLP HDTV. If you are watching an analog broadcast of the original "The Honeymooners" from a station 30 miles away with a thunderstorm in the area, your HDTV isn't going to make the signal look any better than it does on your 12" portable b/w TV set, except maybe the tape smear and broadcast static will be in higher resolution. That is exactly analogous to recording a heavy metal garage band recorded by someone with limited recording experience through SM57s and MXL990s plugged into Eurorack preamps. Whatever converter you use, setting it to 96k isn't in and of itself going to make the recording sound any better, except that the shortcomings in the recording will be more apparent because they are more accurately reproduced.
And finally, back to the practical side of things. Let's say that in 5 years, 96k does become a standard. Upgrade *then*, not 5 years ahead of time. Why? because 5 years from now you're not going to be using 90% of the non-vintage gear you buy today, it'll be too obsolete. I say this as I stare at my "state of the art" ADAT-XT and look at the $250 dongle that came with my original Cubase/VST, both of which are just collecting dust now.
One almost never catches the technology rabbit. When they do, the rabbit is near the end of it's life and dies too quickly to make the chase worthwhile.
G.
