B
BRDTS
Member
This actually started some time back so I moved to using other Tascam machines I have when needed. Thought some of you transport gurus may have an opinion on this before I haul this over to Montebello.
Reel motors have decided to not move tape .. at all ...in play/ff/rew or spool. Whether tape is loaded or not, capstan runs all the time .. which normally it wouldn't unless tape is across the red optical light in the path.
So those are two weird things at the same time.
I cleaned the optical area a few times and that doesn't seem to be the problem, although the capstan continues to spin even with no tape loaded.
So basically, no reel movement. I can load tape, hit "play", pinch roller engages, and basically the capstan will pull tape and spill it.
I have some card choices there in the back that I suspect may be the culprits, including possibly the tension servo amp card or capstan servo amp card. But this gets into areas, I'm not really in to. I pulled several of those cards for the very first time today and other than 23 years of dust, nothing seems blown or burnt out on them ... not that they would.
I've been eyeing another couple of 8516bs out there to have an extra and for parts and cards to swap out. Or, maybe I'll just take this over to Montebello and dump it in their laps. Or maybe this will just be the end of my 8516 era.
Any off-the-top-of-your-head tips on what to check regarding the transport cards?
By the way, looks like someone posted a partial 8516b manual pdf if you feel like some boring reading. Although schematics aren't there as those are another additional couple of hundred pages.
http://scc-344-recording-arts-fall-2009.wikispaces.com/file/view/Tascam+16-85B+March+2008.pdf
