8 kHz static noise in my audio recordings
  • Thread starter Thread starter fictionman
I don't know but if different mics and cables don't eliminate the noise, it has to be something else. If you've used the same interface on 2 different computers and still had the noise, the interface and it's interconnects are the next place to look.
Yes, I understand.
But it won't be easy to test this, because I have only one audio interface...
Thanks for help
Yes, I understand.
Thanks for help
Take your laptop to a completely different location, not just another room in your house, to see if the noise follows you. If it does, it isn't interference from without but a failure in your interface.
There are two antennas about 1 kilometer (0,6 mile) from my flat.
Do you think it could be this?
I already have a wireless mouse but my keyboard is wired.
And, what do you mean by "I redid the system's speakers"?
Thanks for help.
I got rid of the computer speakers, added a pair of JBL 305s, and fashioned the cables using sheilded wire (basically cut a mic cable in half and changed the XLR connector on one end.)
BTW, looking at the frequency spectrum of your noise, there were some peaks around 1000, and then it looks like you have a pair of noise peaks at 8K and 16k which are very similar, like one is a second harmonic of the first. I'm not sure what it could be. 8k would have to be the fundamental, as there is nothing at 4kHz.
Since it seem this could be RF getting in via the microphone try wrapping it* in extra thick chicken foil taking care that foil grounds via the XLR body. Also check with a meter that pin 1 of the XLR connects to the shell. This used to be contentious but now the practice is to bond shells to pin 1.
*Of course, this renders the mic useless but. 'Just testing'!
Did you get to the root of this fictionman? I have EXACTLY the same irregular pattern of issue on dynamic mics/guitar pickups at the exact same frequency on two interfaces. Condenser is crystal clear. I have gone to extensive lengths to try isolate the source to no avail.
Plight
Fictionman was last seen here in 2021 so unlikely, although not impossible, that they'll respond.
I wasn't involved in this thread but reading it back I don't think Fictionman ever described their microphone or cable.
The responses make the assumption of balanced microphone, cable, and input.
I'd bet the input wasn't balanced. ^
Assuming your condenser mic is phantom + balanced, your experience would go some way to supporting that idea.
The advice, I guess, would remain the same - Change everything, bit by bit.
Different cable, different mic, different computer, different power source (battery if possible), different room, different house and, if necessary, different town. :ROFLMAO:
Edit: I've used electric guitars as scanners before, to pinpoint a source of interference.
Might be useful?
Might be useful?
Thanks for getting back so quickly on an old thread! That’s a helpful observation on the specifics of OPs chain.
Okay, time I stop kicking the can down the road, head to the woods nearby and run everything on battery 😂 knock out the gear in isolation in a quiet environment, then build out from there!
The tip with the electric guitar will be helpful because it’s unpredictable. One strange thing I have noticed is that playing an acoustic guitar near a dynamic microphone (not through DI) appears to more readily trigger the response.
If I do crack this nut I’ll come back and post my findings for posterity!
And on GearSpace with the same problem in January 2020 - He got similar advice - some more technical - and with the same results - he ducked out without reveling anything about his microphone or doing anything different than he mentioned here - if I was to guess he looks like a troll seeking attention.
Oh? That might blow my idea apart.
Is that a balanced mic and input, and XLR to XLR cable?
