This isn’t my first 388, but it is my first run in with the type of issue I’m experiencing. When I picked this unit up, all of the cards needed to be reseated, some of the input selector switches needed to be cleaned, heads were a bit gunky, but with even and shallow wear. All simple stuff!
I was still having trouble without occasional dropouts, distorted audio and HF loss on channel one. I should note, playback on channel one is just fine. This only happens when I’m printing to tape, and it doesn’t matter which input I use, or how it’s routed.
So, I did a lot of troubleshooting, and it seemed like getting the take up tension within spec and increasing the record bias for channel 1 worked okay to solve my distortion and HF loss problem.. however I’m still getting some detectable dropouts, and overall unpleasantness. I’m using brand new tape, and it does the same thing with the other reels I have.
Not quite sure where to go from here. The head does look to be in good shape, and great sounding playback on other prerecorded tapes sort of eliminates that possibility. Would love to hear if anyone’s got some ideas
