31 band EQ recommendations
  • Thread starter Thread starter woodzmo
W
woodzmo
Can anyone recommend a good 31 band EQ at a resonable price point, say <$500.
The application would be to EQ a live monitor mix and also to be used in recording.
Any help is appreciated.
The Ashley's fall in that price range, and will work quite well on a monitor mix.
I would avoid using any graphic eq while recording though. Select a different mic, or move the mic position, or change the source sound to what you need for the recording. While mixing, I doubt that a graphic is going to offer any better control than a decent parametric eq.
But do check out the Ashley's for your monitor mix use.
Ed
