trogdor
Hey guys,
I built my first PC last year, an athlon 2100+ etc. from newegg and all went well.
However, I bought some parts off of newegg this week to upgrade my little brothers machine and I'm having some trouble. He had a 600mhz emachines pc from best buy...
So we replaced the motherboard, processor, and ram, and basically plugged everything back in. The only difference was the power switch/led cable from the front panel. It was a different configuration from what was on the biostar motherboard that I bought. So I ripped out the two wires from the 'power' button and plugged them into the right pins since he didn't really care about the power LED's.
I connected everything and put in the processor (athlon 2100+) and it booted the first time to windows (i didn't format the HD beforehand) and started installing all of the hardware for the mobo.
It wasn't seeing the CD drives, so I tried to get into BIOS but all i got at boot was a BIOSTAR splash screen and then it booted to windows (there was no "hit F2 to enter setup").
Anyway, I got it completely booted to windows and it was working, until I rebooted it once more (after all of that hardware was installed) and then at the splash screen i started hitting all of the "F" keys to see if one would take me to BIOS. bad idea. The system just froze. And then when I manually turned it off and then on, it didn't even post anything.
Now when I turn it on, the cpu fan starts, the cd drives and hard drive start whirring, and it basically makes like it's on. However, the monitor doesn't even blink (let alone make that click that acknowledges that you've turned on your pc).
Is there any probability that I fried (or got a faulty) something?
I tried the manual but it's absolutely terrible. If anybody can help me with this that would be wonderful.
[edit]
i forgot to mention that I also put in a new power supply. It is an emachines micro atx case, and only had a 120w supply, so I stuck in a 200w one that I figured would be sufficient, along with 512mb DDR RAM.
trog
[edit]
trog
