Dobro, as Roy and Blue Bear pointed out, there really isn'y a card that records higher than 24-bit... at least as far as the general public is concerned. Never know what is on the *vaporware* workbench these days.
Here is the thing... at 16-bit resolution, you drop the mathematical noise floor to -96dB. And, at 24-bits that becomes -144dB. My Delta-1010s (which are 24-bit resolution) barely make -102dB noise... all by themselves (even though they are rated almost 10dB quieter). Then, there's microphone self-noise and noise introduced by cabling. So, in reality, recording at 16-bit resolution would yeild a really good recording.
The real quality changes can occur at higher sample rates. On another forum, I've seen pretty hot threads about reality verses imagined. But, here goes... CDs sample at 44.1kHz, which is more than enough to reproduce the *normal hearing* spectrum, up to 22.05kHz. But, raising the sample rate introduces other consideratrions -- 1. you get a faster sync. clock, which sometimes yeilds a more stable clock (not always); 2. the higher sample rate generates more samples of a given wave form, which can make a cleaner audio reproduction of the wave form; 3. the frequency ceiling gets raised letting higher frequencies, which some think improve the overall sound... if your recording equipment can capture it.
Hope that doesn't drag this thread off topic!
The WDM (Windows Dynamic Management) option is for support in Windows ME/2K/XP. They are the new way Microsoft manages drivers. Ihave heard mixed responses from others against using ASIO. Most of the time it is latency issues (adding abot 1.5mS using WDM). But, it really depends on the drivers for your sound card. For me, WinME did better with ASIO on a P3/733MHz system. Now, I am on a P4/1.9GHz WinXP system with WDM and no notable issues.
Hope this all makes a little sense. Don't go flaming this thread, if you disagree. I understand. There are way too many threads like that in archive on the other forum
