2 USBs
  • Thread starter Thread starter person11
P
person11
I have my e drum set and my keyboard hooked up through my computer with USB drives, can I record them at the same time but on to diffrent sounds, I use logic express
do you mean like an electronic musical keyboard? and is the edrum an electronic drum kit?
(i couldnt find any info on e drums by doing a quick search so sorry for that in advance)
Technically, either midi or actual audio can run over a usb connection, we need more details about the hardware.
If your audio interface or sound card has multi imputs you can track them at the same time to different track in your DAW. If you are running both through a mixer you can track them to a single track. If you are sequencing from a midi or instrument track in the DAW both the edrum and your keyboard can be trigger through seperate Midi channels. Like suprstar says, we need much more info.
