B bassgirl4 New member Jun 7, 2013 #1 So i know that ideally i'd need to cover all corners with bass traps but currently i can only afford to get two, so where would be the best place to put them for mixing, so for example in the corners behind the monitors or in front? Last edited: Jun 7, 2013
mjbphotos Moderator Jun 7, 2013 #2 It depends on your room set up. For mixing or for tracking might require different placement.
G GIK Acoustics New member Jun 13, 2013 #3 For a monitoring environment, I would cover the first reflection points before anything else.
