			JimmyS1969
MOODerator
Looks like the unit has optical outs. Just need a cable to connect the second unit to the main one.
From the specs from Maudio:
"Standalone operation
The ProFire 2626 doubles as a standalone 8-channel preamp, 8-channel A/D-D/A converter and digital format converter. In standalone mode, the eight analog inputs route to the first eight ADAT optical output channels. This facilitates use of the line, instrument and mic ins—including the preamps—with other digital gear. Similarly, the first eight ADAT optical input channels feed the eight analog outputs to provide D/A functionality. You can also disable the D/A conversion to allow the analog input channels to route to both the analog and ADAT optical outputs—transforming the ProFire 2626 into a standalone 8-channel mic pre with eight discrete analog outputs plus 8-channel ADAT output. When the second optical port is not used for A/D conversion, the ProFire 2626 can also convert coaxial S/PDIF to optical S/PDIF."
I am not a guy who uses firewire, so not sure what that involves. All I know is that a DAW will only recognize one ASIO driver at a time. Therefore the reason for using one unit that has ADAT inputs.
