N nova recording New member Jun 21, 2006 #1 I have a 16 track (Zoom) recorder (similiar to Tascam, et c.) I know the generals, but need advice with mixing, eq, effects, etc.
Dogbreath Im an ex-spurt Jun 21, 2006 #2 That's about a books worth of writing... What is it you need help with? Each one of those things (eq, mixing fx) are subjects in themselves. If you're already familiar with your owners manual...I'd suggest using the search function here and spend a few hours reading. Good luck.
Dogbreath Im an ex-spurt Jun 21, 2006 #3 Try these... http://www.tweakheadz.com/guide.htm http://www.looperman.com/tutorials.php http://www.inthemix.com.au/forum/showthread.php?t=128457 http://bruceamiller.us/bamaudioschool/index.html
Dogbreath Im an ex-spurt Jun 21, 2006 #4 I found 1 more that's pretty good on compression... http://www.digifreq.com/digifreq/article.asp?ID=20 A good read, I thought. Hope it helps.........
N nova recording New member Jun 21, 2006 #5 Dogbreath said: I found 1 more that's pretty good on compression... http://www.digifreq.com/digifreq/article.asp?ID=20 A good read, I thought. Hope it helps......... Click to expand... thanks a lot, will check them all out.
Dogbreath Im an ex-spurt Jun 21, 2006 #6 AHA! I KNEW there was another I was wanting to find... http://emusician.com/mag/emusic_equal_time/index.html decent one on EQ.........
