T
thesedaze
I'm in a bind, and figure there's some smarties on here who have recording experience and can perhaps work me through this issue.
Currently working with a digi002, I have 8 simultaneous channels available. This records at 24/96. I'm wanting to record 16 channels at once, so I looked into the alesis Ai3 unit which connects via ADAT on the Digi002. The first issue encountered with this setup is that ADAT only allows for 48k, not 96...not sooo big of an issue really tho. The Alesis unit has it's own ad/da converters, but are limited by the ADAT's restrictions. I'd like to get the same converters being used for all of the channels anyhow, and don't want to be restricted by ADAT. I was looking into A/D converters, and Apogee seem to be the best of the best right now with their a/d conversion as well as word clock (the new Big Ben). The second problem I encountered is the fact that I have no way of hooking up an Apogee a/d converter if I'm already using the ADAT for the Alesis unit, and also there's the issue of being restricted even more with ADAT since the Apogee can get such a high kHz going (up to 192 I believe).
I thought 'well maybe I can get a second digi002 and daisy chain it somehow so I can use 16 channels simultaneously AND use the apogee a/d converters'....apparently digidesign does not support daisy chaining of digi002's. The only thing I can do in terms of upgrading the a/d converters is using only the 8 channels supplied in the 002r, and using something like an Apogee rosetta800 which has a lesser quality clock than that of the new ad16x, but still quality nonetheless. It also has d/a conversion which is nice for mixing.
So the basic issue is that I'm restricted to 8 channels with this setup. I really enjoy Pro Tools, but if the only way I can get a solid 16 channels utilizing Apogee converters to the max, it seems as though I'd have to upgrade to the HD unit, which seems atrocious. Is this really my only solution if I wish to stay with pro tools?
How about if I didn't HAVE to use Pro Tools, and just went with something like Nuendo.....what's a hardware setup where I can have:
-16 channels i/o
-ability to use all 16 channels of an apogee a/d converter/word clock
onboard preamps aren't necessary, but are definately a bonus if they are worthwhile.
Thanks
-16 channels i/o
Thanks
