1/4" Leader?
  • Thread starter Thread starter bournemouth
B
bournemouth
Hi,
New here and to the world of Tape -so I apologize if this is an ill-informed question.
Just acquired a couple 388's and am itching to get down to work.
I have brand new tapes and a take up reel. Should I put leader on the tape? And if so is there a preferrable sort to use?
Thanks,
Mike
bournemouth said:
Hi,
Just acquired a couple 388's and am itching to get down to work. I have brand new tapes and a take up reel. Should I put leader on the tape? And if so is there a preferrable sort to use?
It will work without leader. I didn't get any for a couple of years, but you'll want to leave a gap at the start if you don't. Being overcautious I leave about 30-60 seconds blank at the start and end.
Now, leader type. Ultimately it's a matter of personal preference. I use white at the start and red at the back, like the lights on a car. That way you can tell if the tape is wound forwards or backwards.
Left for a couple of years, the recording will seep through to the adjacent layers creating a sort of echo effect. If the tape is stored in a rewound state, this will tend to produce a pre-echo effect. If the tape is wound all the way to the end you'll get an after-echo which is less noticable. If you colour-code the leader you'll be able to tell at a glance which way the tape was stored.
Red leader has a disadvantage on the Revox in that it triggers the end-of-tape sensor and stops the machine, but Tascams don't do that.
You also might consider using paper leader which you can write on and doesn't usually acquire a static charge like other materials.
