antispatula said:
wait, I don't think I'm clarifying enough, I'll make it simple:
1. What sounds better (from original tape to mixdown tape) , 1/2>1/4, or 1/4>1/4, or the same? Would there be a difference in 1/4 8 track to 1/4 stereo, and a 1/8 8 track to 1/4 stereo?
Each recording stage will add tape hiss.. but 1/2" stereo will add less hiss than 1/4" stereo would.
I think that's basically what you're asking.
Long version follows. I think I've said most of this before
To answer your earlier question, tape hiss depends to an extent on how large the recording area is. You'll get a better signal-to-noise ratio with half-inch two-track than with quarter-inch two-track.
Likewise for multitracks: 8 tracks on 1" tape (Atom Heart Mother, Court of the Crimson King etc) will work without noise reduction, because each track is the same width as a single track of 1/4" 2-track.
With 8 tracks on 1/2" tape, the tracks will be the same width as 1/4"-4track tape. Some people are okay with that.. other people want noise reduction.
With 8 tracks on 1/4" tape, the tracks are the same width as cassette tape. This is okay for 2-tracks, but with 8 it is not nice and you invariably use some form of noise reduction. For example, the A8 doesn't have Dolby On/Off.. it calls it 'Internal/External' because you'd have to be mad to use no noise reduction on those machines.
In short, the wider the tape the better. I'd like to use 1/2" 2-track, but I can't really afford it and besides, if 1/4" 2-track was good enough for Genesis, Pink Floyd, Rush and so on, it's good enough for me.
