tubedude
Active member
This isnt mine, I wish it were, but I've been experimenting, and lemmee tell ya, the cymbals are there just right, everything is nice.
2 overheads and a kick... I rarely even LOOK in this forum, but this deserves a look by everyone that might be interested...
heres the method, copied from someplace else... Credits to RECORDERMAN...
here's my trick. It's fast and it works perfect every time.
1. Place the "Left" overhead mic directly over the center of the snare at the hieght of two drum sticks-held end-to-end(from the center of the snare, straight up, to the capsule of the mic).
2. Next; take the drum sticks (still held end-to-end) from the center of the snare over to above your ( i.e." the drummers") right shoulder and place your "right" overhead mic here.
3. Fine tune the placement by using a mic cable and measurinb the distance from the center of the Kick to each of these mics is also equidistant from the kick and snare.
4. listen with headphones and have the drummer lightly hit his kick drum, and adjust the "right" mics angle until the kick is in the middle of your "image".
What this has done is:
1. Place the snare & the kick in the center when you pan these mics hard left and right.
2. Place the overheads in a position which is in-phase with the kick,snare and overheads.
3. balanced the over heads so that the Rack and floor Toms (as well as all cymbals) are correctly ballanced.
this is actually a great "picture" of the kit at this point. maybe a hair of Top end (depending on what mics your using) and a little this, and a Kick mic. BUT whatever you add (snare mics, toms, etc) you'll now be inphase. This also makes your snare & toms louder inrelation to the cymbals & is more of a true OH mic set-up (Not just "cymbal" mic's )
It may look weird but try it...it trulelly ROCKS
