plautus
Member
guys, is the curta9in working>?> can u judge the sound ;pls?
what!? I can still clearly hear echo. But I dont know if it's worth having curtains in my room over not having any.There are no room echoes, so if you are just trying to get a dry sound, you have succeeded.
Always worth with any recording setup to periodically do a "silent" recording? Have mics/ instruments setup as normal and gains similarly then run for 20 seconds or so keeping as quiet as possible. Run the resultant clip through something like Right Mark Analyser ( 44.1kHz, 16 bits) You will then see any bumps that could be possible noise pickup due to induced hum from poorly sited mains leads or especially line lump PSUs!You might also let things run for 10 seconds or so to listen for extraneous noise (your noise floor). A silent room is your goal.
do they add boxiness?What exactly do you want to treat the walls for? This is getting silly. You ask us, we tell you, you ignore it and carry on about the curtains?
It sounds fine. Unless you can focus on what it is you don't like - you won't make progress.
If you want to improve the whole thing, the next thing is to practice your diction, delivery and timbre. I listen to audiobooks while driving, and recording quality and subtle stuff doesn't matter - what does matter is that the voice remains consistent even when it is recorded days apart. There isn't much you can do with your voice - it's sort of fixed, but you can deliver it better with practice. You have trouble with the W sound, it often comes out as V, not W and the words 'what' and 'was' and need correcting. You also say lodov instead of lot of - these things will be more vital for English speaking listeners. It isn't bad - but your accent slips every now and then. That said, my language skills are pathetic in anything other than English - but it's maybe something to consider for success.
The room sounds fine - the curtain/no curtain recording shows the space works pretty well. For the spoken word, I would advise stopping spending money now. If it were me, I would send them back for the small difference they make.
