I messed around with it last night and did just that. Didn’t realize it had direct outs to each channel. As far as the line switching goes, could I plug in a sampler/sunth into inst input and use the switch for that method? Or would I have to get a DI box before I go int inst input?
Fork! DI boxes cause a lot of confusion. You can plug the output of most "line'ish level" devices including synths, into just about any input that is NOT a mic input (and even then no harm but probably won't work well)
The almost only time you need a "proper" DI box is when you want to plug a passive electric guitar into a mic input on a mixer, AI or desk. The DI performs two basic useful functions. One, it presents a fairly high impedance to the guitar, though passive boxes rarely deliver much above 200k. Two it has a very low impedance, balanced output at mic level which allows a very long cable to be used.
A third incidental advantage is a ground isolating function that can help avoid ground loop noise.
N.B. some things are called "DI boxes" that are not really. They are 1:1 transformer isolators.
* "Ish because levels in this game are ill defined and all over the shop! Very loosley we can put signals in the 500mV to 10V (rms, look it up) firmly in the " pro line level" slot. 20mV to 1 V rms would be "instrument/domestic audio and embraces the -10dBV "guitar pedal" level of 316mV rms. Mic level I would say is 1mV to 100mV but of course depends on sound level.
As Jay says you can plug virtually anything into anything and check the result. Two things to avoid. Power amp outputs ONLY go to speakers or proper loads. Phantom power ONLY goes to things designed to handle it.
