Xenon 6
Member
So I am thinking of setting up ATMOS in a 7.4.2 configuration. The main front speakers will be Mackie HR824's. I am thinking of 8 JBL LSR306P MKII (I already have 2) for the surround and top speakers, and PreSonus Pro 10 Sub for sub woofers. They claim to get down to 20Hz. There is a total of 13 speakers. Most of the speakers won't do that much so they only need be of moderate quality? So speakers sorted? Also, I am just doing music, it is not like it has to be a certified ATMOS room for cinema releases.
I have 2 RME FireFace 800 interfaces that connect to my Windows PC via firewire. (Total of 16 analogue outputs). This has been a really solid setup for me for many years.
I use Cubase and that appears to have good support for ATMOS.
This is where things uncertain for me. I have always worked with a hardware mixer for my audio plumbing. The Mackie CR1604 VLZ is only a stereo output. Even if I use all the 4 stereo mix buses the only gets me to 10 outputs, could do 7.1 but, not enough for ATMOS.
I am thinking I plug each of the 13 speakers directly into an output of the Fireface 800s and set the physical outputs up on an ATMOS output bus in Cubase. From there I just control the output volume I want with the Cubase master fader? At low volumes I won't have much bit depth in my monitoring setup?
Most of my tracking I would just continue to do in stereo through my mixer. ATMOS only becomes an issue when I want to do the mix?
Has anyone done something like this? Can you give me suggestions?
I do hope the required solution is NOT requiring a Grace Reference Monitor Controller, or if we do need something like this maybe Behringer produces a budget friendly alternative?
Is there anything that takes a dual ADAT inputs and gives me the required 13 speakers outputs with a master volume control?
I have heard Spotify and Apple Music won't accept mixes unless they are in ATMOS format? If Dolby can get ATMOS installed into the majority of new cars then it will have so much traction we will all have to go down that path. I am also thinking a big part of the music listening experience will become the soundscape it creates.
ATMOS suggests some interesting approaches for multi-microphone recording techniques. This will be interesting to explore.
ATMOS Remixes
I am also thinking there will be huge amounts of work available using AI to un-mix classic albums, then remix them in ATMOS. This may present opportunities to add new vocal harmonies and other instrumentation, hopefully with the input of the original artists.
I had a very interesting experience years ago. I had a rock star in my car for a trip of about 5 hours. I asked him if he minded if I put his albums on. He was happy with this. He started singing along with the recordings, and kept saying "I should have done..." wanting to add harmonies and new lines. I am thinking a lot of artists will love the opportunity to revisit earlier work. The record companies will love the idea of reselling the same old (revised) material in a new ATMOS format.
ATMOS Remixes
