? Tascam FW-1884, am I stuck with a boat anchor.
dogooder
I just picked up one of these for fifty bucks at and estate sale, she fires up and the lights be flashing. Anyway I know nothing about it. I looked at some tutorials and downloaded the manuals. Are the drivers still available for the puter, I read somewhere Tascam no longer provides downloads for the drivers anymore?.dt.jpg
The drivers are online, if you're using WinXP, VIsta or Win 7, or an old version of OSX. Nothing new for 14 years, so Win 10, or OSX past around Snow Leopard might not work. That's the PowerPC era, so it might not work with Intel CPUs.
Can I use it as a stand alone midi controller. I have 4 old poly synths. I have an old tower with windows something on it. It was a gamers computer and he had it beefed up. It has ethernet and lightpipe connections. I fired it up a few months ago and it was still coming on line.
I see it has a headphone jack, can I plug a mic in and some phones to check out if the channels are working?
I have no idea.... At that point, I was using my Yamaha recorder, not a computer. You said you downloaded the manuals, so I guess the answer is,,,,,,,
RTFM! 😜
Apparently it can be used stand alone. Page 28 of the owners manual says:
4 – Control Surface Modes and Operation
4.3 Monitor Mix Mode – (General Notes)
The FW-1884 can be used as a stand-alone 18x2 mixer
in MON MIX mode. The primary benefit of MON
MIX mode is to provide a means of monitoring your
audio inputs in a zero-latency environment. By using
MON MIX mode to monitor the audio from your
inputs along with the audio return from your DAW
application, it is possible to overdub tracks to your
DAW software with none of the audio processing
delays inherent in DAW applications.
Also, it has mic preamps:
4. Mic Inputs 1-8 – Balanced XLR inputs at +4
dBu featuring high-quality mic preamps. These inputs
are wired in parallel with their associated Line Inputs.
I just picked up one of these for fifty bucks at and estate sale, she fires up and the lights be flashing. Anyway I know nothing about it. I looked at some tutorials and downloaded the manuals. Are the drivers still available for the puter, I read somewhere Tascam no longer provides downloads for the drivers anymore?.View attachment 138064
I remember those, it was one of those units people were distraught when Windows 7 came out and they didn't make 64 bit drivers for it. Only worked on a 32 bit OS unless they finally got around to writing a driver. Which I doubt it.
Maybe it would work for this as an interface for my keyboards? I have an older beefed up gaming tower computer, maybe 2015? Nor sure. Windows 10 I think. Anyway, I found a bunch of CDs and one had Cakewalk 6 and another Cool Edit. I haven't used windows for years, I run a Linux system on everything I use now. I managed to install both and have both running. I have five MIDI keyboards, two Alesis QS8s, two Ensoniqs and a Korg. In 1999 I bought the Alesis, my step son gave me an older Mac and I bought a version of Cakewalk for 99 bucks. Loaded it, hooked up the Alesis, I don't remember how? I think I had some kind of MIDI box or something? I told the MAC and Cakewalk, that it was working with an Alesis QS8 and set the switch on the back of the Alesis to MAC, set the MIDI channels etc and it was quite seamless. Cakewalk had all the preset libraries etc. for the QS8. I tried the same thing after that with a Windows OS and never could get it to work. So, If I want to use this, where do I go from here? There are no MIDI ports on the computer, it has USB and one light pipe for sure. I have a cord around here somewhere with a dual MIDI plug and a USB on the other end, can I use that? I don't really know what that cord is for, it came with a bunch of stuff in a trade. The software may be bootleg? " I was able to do this in 99 and would like to fool around some more.
Sounds like those USB to midi interfaces. They work with most systems because they are usb compliant. They would even work in linux. I do remember someone making linux divers, did you see if it works in linux? I can't remember if that driver was added to their firmware db (linux firmware).
The old computer I am speaking of is a dual boot, I can select either windows or Linux Unbuntu.
RTFM! 😜
I have a mic and headphones plugged in. I have read the manual, very little detail on stand alone. I see the signal coming in but no matter how I set anything I can hear nothing. I do not have it connected to the computer. I will try and download the software, install it if it will take it and go from there.
Windows 10 is on that older computer Tried all the windows drivers available and they will not load on that computer. Unless I install an earlier version I guess it is a boat anchor. No great loss, maybe I can dump it on reverb or ebay.
This is one reason I don't like recording with computers, everything may be backwards but it certainly isn't compatible.
That is what the deal with what I call pro-sumer equipment.
This stuff and other firewire interfaces were planned obsolescence. I have a stack of motu that I can't get drivers for and motu don't care. I rethought the way I was setting things up and switched to dante as the digital backbone, then the computer turned into just another device, that I can redundantly set up other computers and redundantly record. I use a dante mixer to get headphone mixes at near zero latency. The next step is an Avid matrix studio i/o and I don't have to change anything since it has Dante i/o
I use a Yamaha 02R and an Alesis HD24. Everything is outboard. I have only used a computer for midi 24 years ago. I know the editing would be quicker on the puter but this stuff does all I need. In case you haven't heard anything I have recorded, we did this on that equipment. If I can do this without a computer I am a happy camper.
I could never budget for an alesis24 and when I did it was already off the market. But some of my projects are more than 24 channels and I don't want to go back to stacking tracks. However, Tascam does have a 32 channel I've been looking at from time to time.
To me, I really don't need the computer because I have nice outboard stuff I collected and made over the years and there are only a few computer plugins that impressed me and most are basically the same but with a different feel to the controls. I was forced into computer recording because embedded gear is expensive (even today)($4000 for the DA-6400 plus $1350 for the dante card).
You can sync HD24s for 48 channels. They are getting cheaper but rarer.
For remote recording, I like the self contained units. They're compact and easy to deal with. I never went the ADAT or HD24 route. It was too expensive for me, paying for kids schooling, a house and other stuff at that point. For home recording now, I have no issues with using the computer. I can do things faster and easier with the computer than I ever did with the self contained units. Fewer limitations, virtually no cost, and for me the quality is great. My AW1600 only has 40GB so I can fill that up quickly. The 16G only has 20GB.
As for things becoming boat anchors, that happens with lots of equipment, not just recording gear. How many VHS tape decks are in the dump? Are you still driving that 1995 Chrysler LaBaron? My 18 yr old plasma TV went to the recycle site a couple months ago. Who's using a 10 yr old cell phone (probably very few since they changed from CDMA to GSM to 4G to 5G. A damn I-phone costs $500 to $1200 and people buy new ones every couple of years. Hows that for planned obsolescence?
When I think of my buddy buying an 80-8, dbx unit and model 5 mixer for about $6K back in the 80s with a pair of JBL monitors, (about 6 months pay back in the early 80s), and then I think about the $500 computer, $350 interface, $300 speakers and $120 monitor I have downstairs, I feel blessed. That's about 2 weeks pay and I don't need to buy tape! Yeah, the computer won't do Win 11 (I'm looking into Zero Patch to take care of that), but I could replace it if I needed for $500. Swap the second SSD and I'm back in business.
Some say planned obsolescence. Others call it progress.
One of these days I will get around to installing Windows XP or 7 on that old computer and go from there. All I want it for is to fool around with midi, nothing taxing. It is on the back burner of things to do. In the meantime the 27 year old Yamaha 02R and Alesis HD24 keep on chugging along quite nicely without any problems or upgrades. I paid 500 for the board and bought the HD24 for 1100 new, some of the best money I have spent except for the 12 dollars for the kitten.
