G
gene12586
Member
Hey all,
So I’m in need of a pedal switcher, and I’m deciding between the Carl Martin Octaswitch MK3 and the Voodoo Labs PX-8, each of which have 8 effects loops. I’m having some uncertainty with understanding the bypass functionality for the two pedals. So for the Octaswitch, the manual says the following:
“Your eight effects plug into the eight effects-loops on the back of this unit (all true-bypass, impedance free gold relays so you can run any of your pedals, new and old without problem), and then by turning on or off the numbered switches in each of eight DIP Bank switches, you determine which effects you wish to use simultaneously in each Bank. There is also a buffered (or not....switchable) Mono input and a stereo Output. On large stages when running long connected cables, there is a definite drop in the high end of your guitar sound (more or less depending on the input impedance of your amplifier). The solution is a built in buffer circuit at the input, so the user can choose between 100% true bypass, or buffered bypass to ‘beef’ up the signal.”
So, let’s say I press one of the footswitches and turn on a particular combination of pedals programmed into that footswitch, and let’s say the buffer switch is set to off. As I understand it this means that all of the pedals that are not part of the footswitch I pressed will be true bypassed. Now if I were to flick the buffer switch to on, what happens? Does that mean that the pedals not part of the footswitch are no longer true bypassed but instead buffer bypassed? Or does it mean that all of the pedals that are not part of the footswitch are still true bypassed but that there is a buffer added to the input of the Octaswitch (where the guitar goes into the Octaswitch) and to the output of the Octaswitch (which sends to the amp)? Or would the buffer only be applied to the input? Or are none of these explanations correct?
As for the Voodoolabs PX-8, the manual says:
“Each of the 8 audio loops of PX-8 PLUS are true bypass and completely isolate each pedal, keeping disengaged effects, along with any unwanted noise they might add, completely out of the signal path for the purest tone possible. The audiophile-quality output buffer of the PX-8 PLUS ensures your tone will be preserved even with long cable runs to your amplifier.”
This seems much more straight forward to understand. As I understand it this is just saying that if I press one of the footswitches and turn on a particular combination of pedals programmed into that footswitch all of the pedals that are not part of the footswitch I pressed will be true bypassed, and then there is a buffer at the output of the Voodoolabs PX-8 (which sends to the amp). Is that right?
And my final question is: Based on your answers to the above questions, ONLY taking bypass functionality into account, which of the two pedal switching systems is better?
Any help is much appreciated!
