Zoom l 20 R not getting on, error message Goodbye see you!
  • Thread starter Thread starter khurram79pk
K
khurram79pk
Hello dear friends, I am facing problem with Zoom L 20 R device is not getting on with error message “Goodbye See You!
Please help me.
I don't understand - this is the shutdown message? Do you mean it will not turn off, or not turn on?
Factory reset available in menu , currently its not getting on
I know nothing of the device, but I'm guessing this is the result of a failed shutdown, which persists when you turn it back on.
It seems to be set as 'card mode'. Is there a card in it?
I would try various different mode settings during boot up.
Also try persistently pressing various buttons during power up, which might get it into a different state.
There could be undocumented button meanings during power up.
If you can get it to come up in any other state, you might then be able to do a nice shutdown.
I would be contacting Zoom customer service. They may have another means to do a reset, or even have an idea of what's going on.
I'm also facing the same error. I tried the factory setting reset but it didn't work. I tried to power on the mixer pressing different buttons but nothing happened.
Does someone knows a solution for this error?
My solution:
  1. Turn OFF
  2. Disconnect USB cable
  3. Switch MODE from Audio interface to USB Host
  4. Take out SD card
  5. Turn ON
After this, I power cycled a few more times and it went back to normal and re-inserted the SD card and lost nothing!
FYI FROM THE MANUAL:
When the power is turned off, the current mixer settings are saved in the project on the SD card.
If they cannot be saved to the SD card, they will be saved in the unit.
