Turning volume down to make kicks shine through?
  • Thread starter Thread starter Robbb
R
Robbb
Does anyone ever lower the volume on one note in a beat that overlaps with a kick/808, in order to make the kick shine through? I am thinking about doing this with a guitar part. Will this technique help? If not? HOW DO I MAKE MY KICKS SHINE THROUGH THE MIX WITHOUT BRINGING THE ENTIRE BEAT OVER 0DB, AND WITHOUT MAKING THE WHOLE BEAT EXTREMELY QUIET?
Now, I don't know, I was only told but...I suspect you are not tracking at the 'regulation' neg 20?
EQ EQ EQ EQ EQ - carving 'space' for everything in the frequency domain.
I agree, It's an EQ issue. Probably too much happening below 300hz. I wouldn't start ducking things out of the way either with automation or any sidechain compression until you have a pretty solid mix happening.
Edit:
(Even then.... I don't think ducking anything out of the way is the answer)
Copy the kick track. Put a compressor on the copy, preferably a "character" type. Long attack. Fairly short release. Squeeze the hell out of it so that it's almost all attack. Add harmonic distortion if desired( a little goes a long way). EQ as needed. Bring up slowly while listening to the whole track until the kick is as present as wanted.
Works with snare too.
Ducking, i.e., using a compressor with a side chain (input from the kick), is a pretty common technique. You generally only want to apply it to the tracks with low frequency content, especially bass guitar.
If you're still mixing, I'd be hoping for a peak of the whole mix still a fair bit below 0dB. Maybe I misunderstood...
I usually start my fading everything not bass below 300 on guitars as a general rule (not a hard fast rule). Then below 300 are just the things I want to sit there. Then bass gets dropped below 60ish.
This usually keeps the mud down so that I don't have to work so much in that area in the general mix.
Once again, this is what I have been doing as an approach to get the kick to come out, bass to sit nice and not have a whole lot of mud.
+1 on this.
Side-chain ducking compression on the kick is a pretty common technique, but I honestly don't recommend it. I've used it personally, and found that there were better ways to get the kick through (eq and distortion usually). These days, the only side-chaining I tend to do is vocals ducking rhythm guitars.
It's also really easy to get that woofy kick effect that you hear on a lot of home-produced EDM these days. Where the entire mix ducks on the kick, and all you hear is a big, flat flump.
With sidechain ducking I go for obvious as an effect, or none at all. I think it sounds much more natural and cohesive if you work that EQ to make the bass/kick slot together like that jigsaw puzzle. Even if I am only ducking 1db it sounds off to my ears.
Only thing I use sidechain ducking for recently is after the Delay, or Reverb sidechained to the source so it will duck the delays or verbs out of the way of a vocal for example, the release on the compressor will bring the delays up in between phrases as an easy way to add more delay without it stepping all over everything. I really dislike ducking the bass to let the kicks shine through. I use the ducking method when I get frustrated and can not get my desired instrument to shine through, but really.... it's a cheat and I'm never happy with the results. To the average listener I doubt it would be noticed but because I know I've sidechained my way out of a problem, it just bothers me.
